Top Cylinder
Old Mar 12, 2015 | 01:55 PM
RJ237's Avatar
Default Top Cylinder
I have a friend who needs to have one of the conv. top pistons rebuilt. Can the car be driven with the top up and the piston removed?
Old Mar 12, 2015 | 03:33 PM
cjd777's Avatar
Good question RJ. WE are doing mine Monday, Jon89 and Joyesjag and maybe Dave. I had planned on not driving mine while they where off in Washington, but if we have some nice days it would be a shame not to. I'm not concerned about it being up as I would just leave it down, I worry about the plugs not being connected and the ECU going ape stuff or what ever controls the little gremlins for the top, when you turn the key on. The top being up might be a different story, as the rams hold the rear arms in place. They may lock and the rams are not in any holding capacity once they are locked.
Gus should chime in here, I hope and we both will know.
Wayne
Old Mar 12, 2015 | 04:05 PM
RJ237's Avatar
I forgot about the plugs. I think I will unplug mine and see if it throws a code.
Old Mar 12, 2015 | 04:34 PM
RJ237's Avatar
No warning light when unplugged. Next, I will put the top up tomorrow and disconnect the cylinder. It should stay locked in the up position without the cylinder, but it certainly looks like no problem driving with the top down.
Old Mar 12, 2015 | 09:10 PM
RJ237's Avatar
The weather was so nice tonight that I went back in the garage and took the cylinder out. It appears the top would stay up, but the quarter windows go down if the cylinder is disconnected. So while there will not likely be a problem driving with the top down, it won't work with it up, although it's probably just a matter of jumping the connection at the plug.
Old Mar 14, 2015 | 07:19 PM
RJ237's Avatar
My final comment. I drove around with the ram disconnected and the fuse pulled. Connected again and everything works.
BadKat174
May 26, 2023 12:29 AM
tsimms7
Sep 15, 2015 12:43 PM
Greg Reed
Sep 11, 2015 08:41 PM
Bcrary3
Sep 11, 2015 10:36 AM
mrplow58
Sep 9, 2015 11:27 AM
