Torque app times
Old Nov 13, 2014 | 06:55 PM
brgjag's Avatar
Default Torque app times
Well with bad back tires that spun or let loose with or with out trac control the best I could get tonight was 7.62 sec in a 0-60, ha ha ha ha
Old Nov 14, 2014 | 01:37 AM
mjlaris's Avatar
When I first got my XKR, with good rear tires, I was chirping the rear tires when I stepped on it at a red light. Therefore, one of the first mods I did was install an LSD. This combined with a 3.27 (vs. stock 3.06) rear axel ratio scares the pants off of me when I step on it at a red light. It also leaves a very big smile on my face for a couple of hours.
Mark
Old Nov 14, 2014 | 07:43 AM
RaceDiagnostics's Avatar
That is a bit embarrassing, lucky it was not a shoot out with something inferior, like a 1979 450SL.
Or a MK1 TT
Old Nov 14, 2014 | 11:25 AM
brgjag's Avatar
well like I said my rear tires are no good, they would got bit and let me get off with out them letting go. New tires I am sure that would come down some.
Old Nov 17, 2014 | 04:12 AM
aode06's Avatar
I find the most common things on our Jaguars that result in poor 0-60 times are
#Owner not using premium gas,so the knock sensors will retard timing
1.Slow responding OEM Oxygen Sensors.
2.Bad spark plugs and coils causing timing to be retarded.
3.Stretched gas pedal cable that needs adjusting or replaced.
4.Clogged fuel filters reducing fuel volume at high rpms,that causes timing retard with the knock sensors
5.Air filters that are dirty.
6.MAF thats dirty or responding slower or reading differently than one of the O2 sensors.
These are "no code faults most of the time,just crappy performance"
Address these issues
Old Nov 17, 2014 | 02:10 PM
brgjag's Avatar
well may back tires are shot, been on it since 06 so they didn't grab real well.
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
