Torque Specifications
Old Jun 8, 2014 | 09:31 AM
Jim D's Avatar
Default Torque Specifications
Can anyone post the recommended torque values for front suspension bits? Particularly the upper control arm (wishbone) fulcrum bolt and the upper ball joint?
Thanks very much!!!
Old Jun 8, 2014 | 11:12 AM
MRomanik's Avatar
Veteran: Air Force
JTIS only goes to 2004
ball joint 60-80 Nm
fulcrum 98 - 132 Nm
Old Jun 8, 2014 | 12:37 PM
Jandreu's Avatar
Well I'm getting ready to do my full front suspension so I went thru the JTIS for my car and put together the attached summary of Torque spec's. These are for a 2003 XK8.
Hope this helps
Old Jun 8, 2014 | 03:58 PM
Jim D's Avatar
Set the wrench at 80 ft pounds for control arm fulcrum bolt! Thank you so much guys.
FWIW, had a bad 'clunk' from front at even a small bump. Replaced sway bar bushings and end links, then replaced upper control arm bushes.
Clunk is about 95% gone! Woo Hoo! Still have ball joints, tie ends, and shock mounts to do.
Old Nov 9, 2020 | 09:37 PM
taylods's Avatar
That's very encouraging. About to start all the front suspension 'bits' on my '05. Terrible clunking at slow speeds driver side. Cheers
MrWhite
19
Jun 14, 2022 07:49 PM
Johnken
Apr 8, 2018 10:21 AM
inactualis
Oct 2, 2015 11:13 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
