Trac ABS Unavailable
Old Apr 12, 2015 | 02:37 PM
jhennigar1's Avatar
Default Trac ABS Unavailable
Once in a while I get the "trac not available" warning on my instrument panel. I also get the "ABS not available" warning at the same time. any feedback on this would be appreciated. 2001 XK8
Old Apr 12, 2015 | 03:08 PM
I've moved your post from the Forums Feedback/suggestions section which is for issues pertaining to the forum itself, to the XK8/XKR section where you will get a better response.
regards,
Steve
Old Apr 12, 2015 | 08:02 PM
RJ237's Avatar
One of the major causes is a weak battery. Stop at a auto supply and ask them to load test the battery. After that there are several possibilities, all related to the abs module and wheel sensors. Here is a pdf that may help:
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Old Apr 12, 2015 | 08:15 PM
brgjag's Avatar
yea get the battery load tested first. If ya have a weak battery the many components in these cars do not like low voltage and can act oddly.
Old Apr 15, 2015 | 03:30 AM
t-stag's Avatar
I had the same problem. The solution is to connect an intelligent battery charger whenever the car is in your Garage. This keeps the battery trickle charged. A lot of the electrical problems are caused by a slightly low voltage.
Steve
Old Apr 15, 2015 | 03:35 AM
Davidsw's Avatar
If not the battery it could be a wheel sensor or connecting cable. I had same messages and it was near side wheel sensor connecting cable.
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
