Tracking vacuum leak
Old Mar 14, 2018 | 05:56 PM
Doug Gordon's Avatar
Default Tracking vacuum leak
Hey y'all, have a silly question. Ok here's go's. I have a 2002 XK8 4.0 BEEN having trouble with codes p0171 and P0174. Trying to track down vacuum leaks. My question is, is it possible for the oil filler cap and the dip stick.sucking in air ? I've noticed it has o- rings around each one of those .and the oil filler cap is showing oil around on top of the valve cover .other than that she's running fine. Just turned 70,000 miles.
Old Mar 14, 2018 | 06:16 PM
Doug,
I've moved your question from New Member Area - Intro a MUST to XK8/XKR forum. This is the place to post technical questions about your model.
Old Mar 14, 2018 | 07:07 PM
RJ237's Avatar
They have both been identified as sources of leaks.
Old Mar 15, 2018 | 05:44 AM
Well that gives me some Hope! Thanks you very much.
Old Mar 15, 2018 | 05:59 AM
The commonest cause of P0171 and P0174 is air intake leak between MAFS and throttle body. Have you definitely eliminated this?
Old Mar 15, 2018 | 07:06 AM
Jon89's Avatar
Leaking VVT O-ring seals will also cause the P0171 and P0174 codes. A relatively easy and inexpensive replacement job. These two seals bake in the engine bay heat and tend to get hard and brittle within just a couple of years. My wife's 2006 XK8 is currently on its third set of them....
Old Mar 15, 2018 | 07:48 AM
Yes ,thanks Gramm
Old Mar 15, 2018 | 07:50 AM
Yo,jon89 sorry don't quite understand what the VVT O- RINGS ARE
Old Mar 15, 2018 | 07:54 AM
fmertz's Avatar
VVT seals Part# AJ82856
Old Mar 15, 2018 | 08:04 AM
Rocker cover valve seals ? Is that the ones under the valve covers? Cause mine are showing alitte oil on top of the spark plugs.just keeps getting better.
Old Mar 15, 2018 | 08:53 AM
NBCat's Avatar
If you have oil present on the spark plugs, it's only a matter of time until coil unit(s) short and cause a misfire. Replace the VVT seals and if the cam cover gaskets and spark plug boss seals are leaking, they should be replaced too.
andersen06
Feb 25, 2022 11:03 AM
MK2
Aug 5, 2017 11:53 AM
new mexico
Apr 29, 2017 02:28 PM
heflirob
Oct 21, 2015 06:39 PM
joycesjag
17
Mar 31, 2009 10:04 AM
