traction control fail/stability control fail
Old Jun 27, 2010 | 07:32 PM
Gus's Avatar
Gus
This is a good post with the ABS circuit board repair https://www.jaguarforums.com/forum/s...ad.php?t=37907
Old Jun 27, 2010 | 08:37 PM
DaveNC's Avatar
Sam I would have never thought of that, and awesome tutorial.
hemm, tega cay? So close to me, maybe 30 minutes.
Old Jun 29, 2010 | 05:42 AM
jbhemm's Avatar
DaveNC,
where do you get your car serviced?
Old Jun 29, 2010 | 06:35 AM
DaveNC's Avatar
Originally Posted by jbhemm
DaveNC,
The car is from Atlanta and was serviced by a Jag dealer there. I just got her 3 weeks ago. If you come across any good mechanics in Upstate SC or South Charlotte, please let me know. I'll do the same.
-- still no sign of the stability control fail message -- I may tackle cleaning the abs sensors this weekend just to be sure.
Old Jun 30, 2010 | 12:51 AM
chaseatl's Avatar
Default XJR had the same problem
I looked down at the dash one day and I saw traction control fail/stablility control fail/abs fail. I was on the way to the dealer to get an oil change. They checked it out and they said I needed a new ECU that would cost $3000. The service advisor said most people don't replace it and the car continues to run fine and still have traction control/stability control/and abs brakes.
Old Jun 30, 2010 | 07:59 AM
Reverend Sam's Avatar
ECU??? I haven't heard that one before. ABS control module, maybe, but ECU?
Old Jul 26, 2010 | 02:05 PM
talon's Avatar
I just had the same issue pop up on my 98 over the weekend (stability/traction/ABS). Seems to be fine most times when starting cold in the morning, but it happens during cold starts mid day. At first I thought it might be due to the miserable heat wave here in Charlotte, but this thread has me thinking I'll be checking the sensors as soon as it is cool enough to step outside again.
Old Jul 26, 2010 | 02:56 PM
  #28
H20boy's Avatar
the most common areas of concern on the ABS/traction control issues are
(1) wheel speed sensors (dirty, and/or damaged)
(2) harness damage (wires and/or pins)
(3) ABS module internal short
(4) ABS ring in the hub damaged (rare)
Old Jun 29, 2012 | 07:26 AM
  #30
cbxsage's Avatar
Default Repairing ABS Solder Joint
Originally Posted by Reverend Sam
Dave, this is apparently a very common problem. It usually caused by one of two things; either dirty wheel speed sensors, or a bad solder joint in the ABS module. Both are fixable by a novice. The wheel speed sensors are super-easy to clean. The bad solder joint is a little more complicated, but it's do-able, too. Here are links to the instructions to fix both problems:
Cleaning the wheel speed sensors
Cleaning the sensors is the place to start since it is so easy.
Rev,
I have done a lot of work on my '99 XK and your videos were a massive aid. Thanks. I want to check out my ABS module solder joint but your link doesn't work. Can you repost it for me? I have just subscribed to your YouTube channel and I didn't find a video for this there.
I highly recommend anyone on this forum take the time to check out these videos, highly informative, step-by-step, and ReverendSam does it in real-time and makes it simple and easy by taking out all the guesswork and skinned knuckles.
Thanks again Sam.
Old Jun 29, 2012 | 07:44 AM
  #31
Gus's Avatar
Gus
This link should work JagRepair.com - Jaguar Repair Information Resource It also has additional information that might help.
Old Jul 27, 2023 | 09:12 PM
  #32
CBricker's Avatar
Default Abs light on stability and traction control fail
Abs module.
Ok quick breakdown. Ended up driving in a downpour on a rough road and had traction control stability control fail ABS light on. I did not have any engine light come on when I read the codes there was none besides the code everything is fine. I have cleaned all the wheel sensors and still have the same issue. What's weird is sometimes I start it it pops up and other times no warning light until I drive and sometimes it's fine . Breaking feel normal. So I took the ABS control module out not just a little hole in it to check in there and I work with acrylics so fixing is no issue well when I get into the control module it's like a rubber coating so I had to remove it from over the pins. Well once I remove the rubbery substance the one pin looks like it's cracked in the solder but it's so small it's hard to tell. And when you look at the picture that's not scratch marks on the board that's the rubbery clear stuff. So here's my question do I just need to add new solder to both the pins?
Old Jul 28, 2023 | 07:52 AM
  #33
CBricker's Avatar
Update : Well at 4am I decided to remove some of the old and replace with new. But before that I got out my microscope and most deffently one was cracked all the way around and the other had some very small cracks. So I threw some flex on it and fixed him up. I would like to thank everyone for there detective work I love this group. Now I just need to get a new passenger side mirror. I swerve to miss a dog and put my mirror on somebody's open mailbox and busted my mirror. Thank you group!!!!!
Old Jul 30, 2023 | 03:51 PM
  #34
CBricker's Avatar
Question for anyone out there. I had to remove this rubber substance to fix the module. Can I use rubber cement on the circuit board in the module, to replace the rubber I pulled off??
42Ajd
Dec 30, 2015 09:45 AM
FtypeRRR
Sep 26, 2015 05:46 PM
Steve10
Sep 20, 2015 12:27 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
Johnken
Sep 15, 2015 05:46 PM
