transmission
Old Feb 4, 2016 | 04:41 PM
Sabrina's Avatar
Default transmission
Hey guys...
My XK8 is slipping in first gear, you have to baby the throttle to get it going, second gear on up is fine. Shifts hard from 3 down to 2 when stopping. Backs up fine. Too much throttle from a stop and although it rolls forward, it feels like it jumps into gear and then throws a "Transmission Fault" warning on the dash. Starting with the gear selector in 2 rather than D does not help.
8oz of fluid added through the cooler line did not help.
Is it worth changing the fluid or does it sound like the A-drum and if so, does anyone know a trusted transmission repairperson near the NW side of Chicago/Park Ridge area?
95,000 miles--20,000 since I bought it. So, I have gotten my $10K purchase price back out of it at a reasonable 50 cents per mile.
A dealer is quoting $4500 over the phone to rebuild it. I could buy a 'new' used one for that.
Suggestions?
Old Feb 4, 2016 | 06:49 PM
test point's Avatar
Yes, classic symptoms of 'A' drum failure I am afraid.
As the years have passed the available used transmissions are getting a little long in the tooth so a better long term solution is a rebuilt ZF. The 5hp24 is not all that unique or mysterious and a lot of transmission shops rebuild them very effectively. More shops do not or will not touch them.
Your question of a local referral is the best solution. Where I live in rural Georgia no one even wants to change the ATF.
Old Feb 4, 2016 | 07:16 PM
sweez's Avatar
I live just south of you in Elmwood Park and there is one on craigslist for $1500 that says it has a blown engine, but it also says it has a new transmission.
dfieldsend
Aug 8, 2016 07:22 PM
Ungn
May 24, 2016 05:15 PM
Dr. Wood
Jan 22, 2016 07:53 PM
Jaglover02
Jan 20, 2016 12:47 AM
al_roethlisberger
Jan 11, 2016 01:17 PM
