Transmission Control Module
Old Jun 17, 2020 | 11:37 AM
Dan Clark's Avatar
Ok- Posting for anyone following this thread. I took it to a transmission specialist and he said mechanically it is fine. He reset the control modules and said it ran good.
I drove it home and got the DISC Control error. :-(
Old Jun 17, 2020 | 12:31 PM
crbass's Avatar
Default Good news, bad news
DSC? As in dynamic stability control? Good news, tis something else. Bad news, tis something else. Do you have a code on this one?
Old Jun 17, 2020 | 12:56 PM
Dan Clark's Avatar
Yeah C1155 which I believe is the left front wheel sensor.
Old Jun 17, 2020 | 01:21 PM
motorcarman's Avatar
Likely the 'link-harness'.
bob
Old Jun 17, 2020 | 01:24 PM
XK Owen's Avatar
Was gonna say wheel speed sensor. Most common DSC fault seems to be that and it can also affect transmission decisions.
First thing is to remove and clean it. Videos of how to do that on YouTube.
If that doesn't help, check all wiring for damage and then try swapping sensors around to see if the fault follows the sensor. If so, order a replacement.
Old Jun 17, 2020 | 01:31 PM
crbass's Avatar
That is good news. Probably a broken wire, common, easily fixed.
Old Jun 17, 2020 | 01:51 PM
Dan Clark's Avatar
Thanks guys! I will clean and test it and let you know what happens. :-)
Old Jun 22, 2020 | 02:16 PM
  #28
Dan Clark's Avatar
Final update. I cleaned the speed sensors and switched the front ones. Ran it all weekend with no problems!
Thanks to all!
Old Jun 23, 2020 | 05:53 AM
Jon89's Avatar
I have been cleaning all four wheel speed sensors at every oil & filter change / tire rotation (6,000-mile intervals) since March 2013. No DSC warning light issues since beginning the cleaning routine. You do need to check the wiring harnesses for cracks and splits whenever the wheels are off the car, though....
Terrance39
May 29, 2020 11:05 PM
Napster
Sep 4, 2019 04:47 PM
Brutal
General Tech Help
Aug 23, 2019 06:35 AM
95Leaper
Sep 27, 2016 08:53 PM
03Xtype
May 16, 2016 09:57 PM
