Transmission HELP! Code P1722
Old Apr 11, 2008 | 08:15 PM
FactoryJaguarTech's Avatar
Default RE: Transmission HELP! Code P1722
P1722
Transmission oil level low
transmission Selector cable adjustment / installation incorrect
Output speed sensor problem (Refer to P0721 Possible Causes)
Transmission mechanical failure
I would look at shifter adjustment first.....possible rotary switch alignment. Do the lights on the J-Gate light up normally? Manual shift mode too?
Old Apr 11, 2008 | 08:36 PM
It is actually starting in 5th gear. Limp home mode. I would take it to dealer, pay the 1 hour diag and have them diagnose in person. It could be the output speed sensor. They can monitor that.
Likely you are going to end up putting in trans.
As for the XJ and XK....should be the same trans, but you can speak to dealer parts dept and see.
Old Apr 11, 2008 | 08:45 PM
jag_genius's Avatar
same trani.. but if vins are too far apart will have no cruise.. control
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
philwarner
25
Jun 26, 2021 05:43 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
mrplow58
Sep 9, 2015 11:27 AM
