Tread plate
Old Apr 7, 2023 | 03:03 AM
Ant Buck's Avatar
Default Tread plate
The car needs some welding so i need to remove the carpet, but i can't see how to remove the tread plate. I don't really want to prise it off at the moment if that's not the way to remove it. Many thanks. Ant.
Old Apr 7, 2023 | 03:24 AM
It's glued on.
This is the relevant section from JTIS:
Warming gently will help soften the adhesive and a plastic trim tool is the best thing to lift an end although a credit cars will do the job.
I prefer to use a length of fishing line or thin strimmer cord with a sawing motion between the scuff plate and the body panel to release it.
Old Apr 7, 2023 | 03:26 AM
Ant Buck's Avatar
Thank you for the info.
Old Apr 7, 2023 | 08:17 AM
motorcarman's Avatar
You might try a heat gun or hair drier to warm the 'double-sided tape' attaching the trim panel.
Old Apr 7, 2023 | 09:13 AM
dfbender's Avatar
Originally Posted by GGG
It's glued on.
Fishing line is the best way to go.
JK_XKR
Aug 4, 2020 12:58 PM
catroad
Aug 8, 2017 05:10 PM
37driver
Nov 7, 2016 10:36 AM
j_bond
Mar 21, 2011 06:19 PM
Disco stu55
May 3, 2009 11:27 AM
