tubing abrasion causes Oil and AC lines to leak
Old Jul 5, 2020 | 09:07 PM
ragtopXKR's Avatar
Question tubing abrasion causes Oil and AC lines to leak
Not sure if these lines were routed correctly during 2nd engine replacement. Should the right side oil cooler line be routed above the AC suction line that has the 4-wire pressure switch? The oil line rests on the AC line but does have flexibility to me moved higher and away from contact at this crossing point.
Abrasion failure point for oil cooler and AC suction lines.
Old Jul 5, 2020 | 09:34 PM
motorcarman's Avatar
The TSB is NOT for your VIN range but info in the TSB might help?
File Type: pdf
Old Jul 6, 2020 | 11:26 PM
ragtopXKR's Avatar
Motorcarman, Thank you for sharing the TSB. The drawings are helpful will get me to checking for missing "intermediate connector securing bolts". I grabbed this freeze frame from an episode of To The Garage. I will use for reference when refitting the new AC line.
ryejag
Jun 14, 2017 08:04 AM
Atlastajag1
Sep 8, 2016 09:23 AM
scrimshank
Aug 23, 2012 05:23 PM
reko19
Aug 1, 2012 02:51 AM
