Turn Signal Audible Output
Old Jul 25, 2017 | 08:44 PM
jaguar51's Avatar
Smile Turn Signal Audible Output
Turn signal audible output not activating, turn signal activates fine just can't here it's audible output when switched on for left and right? What's up with that?
Old Jul 26, 2017 | 08:44 AM
michaelh's Avatar
Perhaps the loudspeaker in the steering column has expired.
Take a look at this thread started by member TexMurphy:
https://www.jaguarforums.com/forum/x...5/#post1633715
Old Jul 26, 2017 | 01:04 PM
jaguar51's Avatar
Wink Turn Signal Loud speaker location...
His vehicle regarding the attached link you sent me is a 1996 and the speaker is located in the steering column while my vehicle being 2002 XK8, the dealer today told me the speaker is located behind the dash?....
Old Jul 26, 2017 | 01:18 PM
Johnken's Avatar
Don't all the status sounds go through that speaker?
Ignition off - move shifter towards reverse = Ping ping
Keys in ingition - open drivers door (ding ding)
headlights on - keys out of ignition (ding ding)
If I'm right, that'll show you if the speaker is working at all.
John
Old Jul 26, 2017 | 01:45 PM
jaguar51's Avatar
Did what you said, I got no ding ding. Is speaker in dash or steering column?
Old Jul 26, 2017 | 02:03 PM
motorcarman's Avatar
The Audible Warning Speaker is in the column cowl (#4 in the diagram Part # LXF2280AA) listed in JEPC.
bob
Old Jul 26, 2017 | 02:08 PM
jaguar51's Avatar
bob
Thank you Bob, your're a big help, I'll try to replace the speaker.
ER
Old Jul 26, 2017 | 02:52 PM
michaelh's Avatar
Originally Posted by jaguar51
...the dealer today told me the speaker is located behind the dash?....
Mmm. I wonder where he looks for the motor.
Thanks, Bob, aka Encyclopediaman
Old Jul 26, 2017 | 03:56 PM
Johnken's Avatar
That was a good one Michealh.
Old Jul 27, 2017 | 03:36 AM
jaguar51's Avatar
Wink
Exactly, how do you know who to believe? You never do.... In many cases your forced to go find out for yourself and good luck with that....
ER
Old Jul 27, 2017 | 03:46 AM
jaguar51's Avatar
Wink Jaguar ignition key cutting/coding
McGuire Lock & Safe - Kansas, locksmith named Josh cut keys for me and did the job right the first time. Must have correct chip in your key that directly matches your model vehicle / make or the newly cut key will fail after the dealer attempts to program it. $87.50 for programming 3 keys at dealer.
Keys available on ebay, see below link:
http://stores.ebay.com/BBB-Car-Key-L...p2047675.l2563
