Two cut wires
Old Dec 11, 2019 | 09:37 PM
Dttannn's Avatar
Default Two cut wires
Hello all, I'm new here and have been enjoying reading and learning from others experiences here for about a month. I was wondering if someone may know what my two broken/cut wires go to or what they are for. One wire is solid red and the other is solid light blue, both laying next to the right motor mount just behind the right side cat converter. They go together and travel upwards to a connector approx three inches higher than the motor mount and attach to the metal wall that runs parallel with the right frt tire inside the engine compartment. If anyone has a clue what they are for I would sure be thankful to know. Have a great night/day everyone. Dave
__________________
1998 XK8 Convertible
(added by GGG)
Old Dec 11, 2019 | 10:02 PM
Dttannn's Avatar
I wanted to clarify on the location of my wiring issue. They are laying on the aluminum subframe, just behind the motor mount, not the cat converter. If you where to look directly down from engine side if the right strut tower just a little aft of the tower and straight down you will see the connector and below that the two wires laying on the subframe. Also I have no engine lights, no noted drivability issues, or missing electrical options I know of. They may have been chewed up by a pack rat which is very common here in the southwest. Thank you again!
Old Dec 12, 2019 | 02:07 AM
Originally Posted by Dttannn
I wanted to clarify on the location of my wiring issue. .....
Welcome to the forums Dave,
I've clarified it a bit more by adding your vehicle details.
vdpnyc
Feb 16, 2017 11:41 AM
featherboxx
Jan 21, 2014 04:20 PM
Randallc79
Mar 4, 2013 08:44 PM
plums
Nov 23, 2012 06:31 AM
M90power
May 30, 2012 05:17 PM
