Tyre pressures?
Old Sep 15, 2024 | 07:09 AM
Ant Buck's Avatar
Default Tyre pressures?
What are the tyre pressures on Double fives 255/55/18 and 245/45 /18.? Many thanks.
Old Sep 15, 2024 | 07:17 AM
RichardS's Avatar
Label on passenger door opening?
Richard
Old Sep 15, 2024 | 07:34 AM
Ant Buck's Avatar
Thanks for the reply, just had a look and the only labels are the jag spec label and airbag label,i can't find it anywhere on the car.
Old Sep 15, 2024 | 07:55 AM
toaster's Avatar
Armrest?
Old Sep 15, 2024 | 07:58 AM
Ant Buck's Avatar
Thank you.
Old Sep 15, 2024 | 08:00 AM
zray's Avatar
I have the 18” double nickels also. With every tire brand I’ve tried I’ve had the best and most uniform tire wear by going to a midpoint between the two factory suggested tire pressures:
my midpoints:
Front : 29 psi
Rear: 31 psi
Otherwise the high published pressure will result in classic signs of overinflation (wear in center of tread). And the low pressure gives accelerated tread wear.
Z
Old Sep 15, 2024 | 08:01 AM
motorcarman's Avatar
All my XKs have that info under the console lid.
Old Sep 15, 2024 | 10:50 AM
RichardS's Avatar
Originally Posted by toaster
Armrest?
Ah yes, I forgot that we were talking about the X100 rather than the X150, so armrest rather than door.
Richard
Wolfy
34
Oct 9, 2016 01:15 PM
landyman
Jan 19, 2013 06:22 AM
jagatlast
22
Oct 9, 2010 12:02 PM
electraglide1600
Jul 1, 2009 06:43 AM
