U1261 Code
Old Sep 22, 2025 | 11:01 AM
XK8WGM's Avatar
Default U1261 Code
Another issue. I pulled a U1261 code warning using expensive scanner. Would this in any way be causing Traction Control light to come on and what is fix?
Old Sep 22, 2025 | 04:33 PM
motorcarman's Avatar
U1261
IC Instrument Cluster SCP - circuit failure
Control Module Pin FC25-14
Possible Causes
SCP -ve circuit: open circuit, short circuit to B+ voltage, short circuit to ground
ABS is on the CAN bus and the INSTPK DTC U1261 will will not set the Malfunction Indicator Lamp.
Old Sep 22, 2025 | 05:55 PM
XK8WGM's Avatar
Would it have anything to do with a Traction Control warning out of the blue after riding for at least an hour?
Old Sep 22, 2025 | 07:12 PM
A hard fault will log a DTC in the ABS module. (C (chassis) code)
Old Sep 22, 2025 | 07:24 PM
XK8WGM's Avatar
In laymen's terms, I am still lost on this. All of the instrument panel gauges and lights are working fine. Just threw a Traction Control warning after driving for close to an hour. Stopped for about 20 minutes, cranked and one mile later threw code and lost power. I pulled over, turned off, cranked and drove another 30 minutes home.
Days later, driving around checking codes and then came home noticing fluid leak on driveway. My son noticed the transmission cooler (I think) pipe was very loose and leaking. In the shop now for re-fill of fluid as I do not know how much was lost. Would that leak cause a TC warning?
Old Sep 23, 2025 | 03:10 AM
dibbit's Avatar
Are you saying the U1261 is the code in question?
A traction control warning would come from a wheel sensor not reading properly, or potentially an internal gearbox sensor not reading (or even a low battery). On the face of it nothing to do with the U1261 code which might have been sitting around in your computer for years without you noticing.
Jon89
Jan 29, 2019 11:44 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
daboss085
May 22, 2012 09:43 PM
test point
Sep 29, 2010 10:21 PM
mark@ddi
Sep 19, 2008 10:53 AM
