Ug DVD NAV pump tower in trunk
Old Oct 15, 2011 | 02:17 PM
mapatton's Avatar
Default Ug DVD NAV pump tower in trunk
Was removing the fill bolt on the hydraulic pump and dropped my wrench. Down the wheel well it went.
Have tried to reach it with a magnet but no joy.
So other than the 4 bolts that are easily seen, what holds that tower in place and how do you get to it?
Still search the disc to see if this is covered. So much for finishing the job today and testing it.
Old Oct 15, 2011 | 02:39 PM
Dennis07's Avatar
There's a sort of tongue that extends down from the back (most outboard) side of the tower and goes down a bit into the wheel well. In other words the bottom of the tongue is below the surface where the four "easy" bolts are found. It has a bolt securing the bottom of it, same size as the other four I believe.
Old Oct 15, 2011 | 03:22 PM
mapatton's Avatar
How do you get to that bolt?
Trying to fish out the wrench with a magnet right now.
Old Oct 15, 2011 | 03:33 PM
mapatton's Avatar
Got it with the magnet.
Note to self: Do NOT drop anything in that area EVER again. LOL
But I am still curious, for any possible future need, how to get that bolt out.
SeismicGuy's Avatar
Absolutely Murphy's law. I wish I had a nickel for every time I was working on a car and a nut or fitting or some connector dropped down into the Twilight Zone. You might try using one of those mirrors at the end of a stick to try and see where the wrench ended up and once you see it you can try with one of those long grabber-type gizmos or put some gum or sticky stuff at the end of a rod, etc.
Good luck!
Doug
Old Oct 19, 2011 | 08:56 AM
dennisw's Avatar
10mm spanner and 2 nuts in my engine bay..never found em
dsnyder586
Dec 29, 2024 07:39 PM
timfountain
Sep 17, 2015 05:12 PM
Jagfastic
Sep 14, 2015 07:41 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
