Unable to put my XK8 in Gear....sometimes?
Old Aug 9, 2021 | 12:01 PM
GooseTx's Avatar
Default Unable to put my XK8 in Gear....sometimes?
Lately I've had problems getting my car to shift out of park. I'm not on a incline that would effect shifting so I assume there is a switch that may need to be replaced??
Thanks in advance for your help!
Old Aug 9, 2021 | 12:42 PM
fmertz's Avatar
Getting out of park requires your foot to be on the brakes. There is an interlock solenoid under the top/left of the shift surround. When it works you can hear/feel a slight thump. There is a plastic plug you can remove to bypass this interlock as needed.
Normally, this is a symptom of a problem brake switch (very common problem). It is a bit of a challenge to replace for some, but the part can easily be rebuilt from cheap component switches with basic soldering skills. The new part is a bit pricy but not out of reach. If the brake switch is confirmed OK (check your brake lights!), then it can be a bad solenoid (much less common, AFAIK). Don't rely too much on a cold test of the brake switch as these have a way of failing on the sometimes schedule, and never when you have a meter to test them.
Best of luck, keep us posted.
Old Aug 9, 2021 | 05:04 PM
Timeisrelative's Avatar
Also check the grounds to the brake light housings. My lights were flickering and my interlock would chatter a couple of times and cleaning up the grounds at the lights seemed to do it.
97xk
Dec 12, 2023 04:42 PM
user 8390
Jun 10, 2021 11:02 AM
user 5722353535
Mar 3, 2021 01:52 PM
02jagstype
May 26, 2017 04:06 PM
Salu498
Jul 22, 2016 07:36 AM
