Upper Front Shock Mounts
Old Aug 12, 2016 | 05:46 PM
obwoodie's Avatar
Default Upper Front Shock Mounts
My car is a 2004 XKR portfolio car with the dealer sticker saying it has sport suspension. Anyone know what that is or how I find out? Reason is the front ride height is supposed to be 15.78" and mine is 14.5". The wheels are OEM BBS 20" and scrape the inner fender liner on hitting big dips in the road. There is a shock mounting plate on the upper end that is big and has some kind of foam sandwiched between two metal plates that collapses. I'm amazed that mine could have collapsed 1" or so. There is a polyurethane replacement but I'm wondering if that is too stiff. Anyone have any experience with this mount?
John
obwoodie@gmail.com
619-994-2907
Old Aug 12, 2016 | 06:22 PM
Jandreu's Avatar
That's a common replacement item on both XK8 and R's. My ride height was 14.5 and replacing the upper mount brought it upto 15.5. Of course while I was at it I also replaced all ball joints, tie rods bushings and the shocks as with 90K plus miles it was time.
Do a search and you will find lots of info
04 2004 Jaguar XKR Shock Mount - Suspension - APA/URO Parts, Eurospare, Genuine, Front Left Upper, Front Right Upper, Front Upper, Rear Left Upper, Rear Right Upper - PartsGeek
Old Aug 12, 2016 | 06:24 PM
John - do a search and you will find plenty of threads on the upper shock mounts including some who have used the poly replacements.
My original upper mounts lasted for 110K miles so I just went with the same and replaced mine with a set from XK's unlimited
JA-MJA2170BD - Spring/Damper Mount, Aftermarket Version Of Original
XKR2000
Dec 8, 2016 07:20 AM
FrankZ06
Aug 28, 2016 07:05 PM
Bhpbug
May 3, 2016 12:26 PM
powerhouse
Apr 2, 2016 02:55 PM
Mar 6, 2007 11:39 PM
