upper tensioner parts
Old Dec 31, 2013 | 09:02 AM
socaljag52's Avatar
Default upper tensioner parts
I am needing to do the upper tensioner on 1997 XK8. Where can I purchase complete parts kit?
thanks!
Old Dec 31, 2013 | 10:45 AM
test point's Avatar
A complete parts kit for secondary tensioners only consist of left/right tensioners and 4 bolts. The most cost effective source has been to shop on-line Ford dealers for '00 - '02 Lincoln LS or Ford Thunderbird tensioner/bolts. If your cover gaskets show signs of leaking or you chose to replace them one of the on-line Jaguar parts sources will have the best prices. Your AJ26 engine cannot use the referenced Ford/Lincoln nor the often mentioned FelPro gasket sets for the later engines.
Old Dec 31, 2013 | 11:32 AM
2000CAXK8's Avatar
Find the price for the tensioners from an online ford parts distributor and then take it to a local ford dealership to buy and have them price match.
Order the shorter bolts!
Kragen-orielly carries 3 different gasket sets for these engines... they will have yours.
Readup on how to remove the dipstick which is in the way of the cam cover. I just cut the stud off with a dremel.
Old Dec 31, 2013 | 12:22 PM
RJ237's Avatar
The dipstick is not in the way on the AJ26 used in the '97.
Old Jan 2, 2014 | 10:42 AM
socaljag52's Avatar
Thanks guys for the information...invaluable!
But, Ford for a 1997 XK*? I thought t'97 was the last year Jag made the engine.
Old Jan 2, 2014 | 11:04 AM
RJ237's Avatar
Jaguar began manufacturing the V8 in 1996. They are still building them. The 4.0L version was supplied to the US market until 2003, whenthey introduced the 4.2L
Old Jan 2, 2014 | 11:08 AM
SNG Barratt USA's Avatar
Former Sponsor
See below link for our products/pricing. We also offer kits for a complete overhaul of chains/guides.
SNG Barratt - The Ultimate Jaguar Parts Specialist
Old Jan 2, 2014 | 04:51 PM
Paul Pavlik's Avatar
That listing only lists the Left Bank Tensioner #CA1512 (at 2 different prices???).
The Right Bank Tensioner #CA1511 is not listed.
Old Jan 3, 2014 | 08:18 AM
Former Sponsor
My apologies I linked you directly to only one of the banks, you can use the ' catalogue subsection' to navigate elsewhere on the engine.
please find direct links below to each number:
http://www.sngbarratt.com/PartSearchResults.aspx?partno=C2A1512
http://www.sngbarratt.com/PartSearchResults.aspx?partno=C2A1511
Plain numbered items are Jaguar Boxed
Parts marked with a # are OEM
Parts marked with a * are aftermarket.
Please do hesite to drop me a PM or email if you have any questions.
William@sngbarratt.com
RoyLittle0
May 25, 2023 02:38 AM
Bcrary3
Feb 21, 2023 04:29 AM
Bowman
Sep 15, 2015 06:54 AM
Tar
Sep 6, 2015 11:24 AM
Bowman
Sep 3, 2015 03:17 PM
