Valance/Undertray Attachment
Old Dec 11, 2011 | 02:13 PM
SeismicGuy's Avatar
The ones that were on the car (looks like there are about 7 or 8 attachments total) are clearly a slightly larger size u-nut. The only way I could have used the one you referred to was to grind away some of the plastic or elongate the hole. The alternative one that the parts guy had was about 1/8" longer in terms of where the hole lined up which made it a perfect alignment.
Doug
Old Dec 12, 2011 | 09:05 AM
XKRacer's Avatar
I took a pic quickly showing the type I use, these are the same as fitted at factory as supplied by Jaguar using the part number I gave you, again I am unsure why they would be different?
Here's a pic of 2, each showing a side against a rule so you can get an idea of size.
Old Dec 12, 2011 | 12:16 PM
SeismicGuy's Avatar
The ones that were in place on the car looked just like yours in basic appearance. The one I bought based on the part number you supplied also looked exactly the same in terms of type but a hair smaller than the ones on the car. I should have removed one of the nuts that were on the car and held it next to the one I bought to see for sure but to my eye (also the parts guy) we both agreed that the ones on the car looked a bit larger than XR87652. Then again maybe the hole in the bumper was in the wrong place which might explain why this was the only attachment (out of the 7 or 8 total) that was missing.
Doug
Old Jun 11, 2014 | 03:24 PM
Jim D's Avatar
Originally Posted by XKRacer
Afraid not Doug a very different undertray on the 05MY and are held on by the clips...eeerrr Doug has shown (OK that seemed confusing, is there a group name for a collections of Dougs?)
Would 'Whole' be an appropriate noun of collection for a bunch of Dougs?
Old Jun 11, 2014 | 10:09 PM
Jandreu's Avatar
Any NAPA auto parts store also carries these.
SeimicGuy, mine if I send you a parts order now that you have an in with the warehouse and all.
Old Oct 29, 2016 | 03:17 PM
Pikachu's Avatar
I also noted some screws went missing on my 2002 X-type.
After reading the above, I went to our local shop - Autozone, in Houston, and the sales was very helpful and showed me the GM BODY GRILL/BUMPER RETAINERS (461030A, bar code 76369 46103). It is plastic, $3.50 with tax for 2. Just push it in, it will open and fits well. It supposed to be retrievable.
Hope the info will help others in the future.
Old Oct 29, 2016 | 07:37 PM
RJ237's Avatar
I used 6mm machine screws and nylon lock nuts. I don't trust plastic fasteners.
Poet
Feb 7, 2025 02:18 PM
mikiep
Dec 20, 2019 07:37 PM
o1xjr
Oct 1, 2015 09:46 AM
JagBrian
Oct 1, 2015 12:52 AM
ChrisJay
Sep 27, 2015 09:08 AM
