Valve nois
Old Jul 25, 2025 | 05:05 AM
Wyss1955's Avatar
Default Valve nois
Hello everyone. I have an XK8 from 1997, Convertible with 80,000 km. Now I hear a clear valve game from cylinder bank 1, back. According to the workshop, the valve game must be rarely or never set. My question: can that lead to a problem?
Old Jul 25, 2025 | 07:45 AM
bladerunner919's Avatar
Have you checked that your tensioners are the later, metal-bodied ones? I'd do that before starting the car any more, just in case, or you could be looking at massive damage.
But it depends on the noise - could be the vvt. Valve clarences do also need to be checked, but 80,000 km is not a huge mileage.
Old Jul 26, 2025 | 04:52 AM
Wyss1955's Avatar
Default Answer
Thanks for the hint. Yes, I had the control chain and tensioner replaced in a specialist workshop about 10,000 km. The noise has only occurred now.
Old Jul 26, 2025 | 12:47 PM
Does the noise disappear if you rev the engine up and then come back after a while?
Old Jul 27, 2025 | 01:35 AM
Pistnbroke's Avatar
I had a tick on mine which came and went ..put it down to piston slap ...cured when I found that the older models had had the oil level raised by 1 cm and I used 10 w 40
You need a mechanics stethoscope to track it down
Anbran
Apr 29, 2023 09:09 PM
Leif
May 28, 2018 03:49 PM
sidescrollin
May 9, 2018 07:47 AM
Oldengineer
Apr 11, 2009 03:48 PM
