Voltage problem help needed please
Old Jun 19, 2009 | 06:40 PM
megatrack's Avatar
Default Voltage problem help needed please
HI,
My Xk8 came back with the tow truck today,
It gave my wife all kind of messages.. ABS, Low brake oil,
restricted power, yellow engine light,etc.
I Just put the code reader on it and no code just the habitual p0111
I have checked the voltage at the battery and it is 11.5v so I
started the car and it goes down to 10.4v So I think the Alternator
is shut. It looks like quite a job to replace, anyone has a
procedure for it or any help would be very appreciated.
AJ
Old Jun 19, 2009 | 09:14 PM
test point's Avatar
JTIS does but it appears to be a real bear. Have the CD? Want me to PM the instructions?
Old Jun 19, 2009 | 09:22 PM
hlgeorge's Avatar
You may just have a weak battery. No load testing can give good results. It can show proper voltage, but when a load it put on it, it can take the voltage down to a point that can give all kinds of errors. Put a load tester on it to check it properly.
Old Jun 19, 2009 | 10:19 PM
megatrack's Avatar
Thanks,
Test Point if you don't mind I would appreciate if you can pm the instructions,
I am sure it is the alternator, I have restarted the car and the Alternator was smoking ,
AJ
hafren
Aug 30, 2023 03:42 PM
jdzubas
Oct 4, 2015 09:14 AM
Jandreu
Aug 29, 2015 07:31 PM
looops
Aug 28, 2015 06:18 PM
divingmom
Aug 25, 2015 07:54 PM
