water pump replacement
Old Mar 8, 2012 | 10:51 AM
jam1white's Avatar
Unhappy water pump replacement
Need ur help again guys. i got water leaking frm the front of the 01 XK8. i heard something the other the day that sounded like the water pump whining. so i think the pump is going out. anyone have a video of pump replacement. thanks
Old Mar 8, 2012 | 12:31 PM
The Coupe's Avatar
I don't know if anyone's done a video on water pump replacement, but I went into JTIS for you, and created a PDF of the instructions for a 2001 XK8.
They're attached. If you don't have JTIS, you really should download it. Look in the sticky section at the top of this forum.
Good luck.
Old Mar 8, 2012 | 04:54 PM
jam1white's Avatar
Wow...that's grrreaat!!! i think i can now do this myself. ur right i need to download that app. another question will i have to remove the shroud or anything else from the front of the car to get to the water pump? hey thanks
Old Mar 8, 2012 | 05:15 PM
Brutal's Avatar
No, take the pulley bolts loose before you loosen the belt, chang ethe belt now if its cracked too. Might as well. And do not buy a metal impellor pump.
Old Mar 8, 2012 | 05:33 PM
oldjaglover's Avatar
It's probably one of the easiest pumps to replace....but don't forget the pan underneath and a place to drain excess fluid (or change it).
Old Mar 8, 2012 | 05:58 PM
Gus's Avatar
Gus
I replaced my pump and crossover just recently. This is my information JagRepair.com - Jaguar Repair Information Resource I hope this helps.
I should note that the “O” rings are not necessary because you may not find them at the parts place.
Old Mar 8, 2012 | 06:47 PM
jam1white's Avatar
Gus...i was wondering about the Oring because i dont see it being shipped with the pump. so how important is it to change it too. thanks
Old Mar 8, 2012 | 07:02 PM
Gus's Avatar
Gus
I asked around and the “O” ring is not provided or on the most part made available so I would say it is not a problem. When I removed the old one it did not have the “O” ring either so my best guess is that it is not a problem.
Note I should say the parts place was a Jaguar dealership
Old Mar 8, 2012 | 07:31 PM
jam1white's Avatar
thanks...you guys have been a great help as usual. the quick response was outstanding!
Old Aug 11, 2015 | 07:22 AM
hod1's Avatar
Default the coupe
I just became a first time Jaquar owner (2001 xj8 59000 miles). My research indicates replacing the "plastic impellor" water pump with the metal impellor PROACTIVELY! What do you think? You commented not to use the metal impellor. Also read that the plastic timing chain will fail around 90000 miles and to replace it with the metal version also. Should I proactively replace it or wait till it gets closer to 90000 miles?Thanks, HOD1
Old Aug 11, 2015 | 12:39 PM
Jag#4's Avatar
The timing chain is not plastic. You are referring to the secondary chain tensioners. There were three generations. The last (best) version had a metal body. These should be changed proactively as the plastic body will crack, the chain will jump a notch or two and you have a dead engine. As in boat anchor.
The water pump decision I'll leave that to you, but I am of the camp that says wait it until it breaks or do it while you are already on some related issue and have it exposed.
Old Aug 11, 2015 | 02:37 PM
brgjag's Avatar
the WP repair on the XK8 is insanely easy to repair and is a cheap part as JAG parts go. I would get the pump with the o-ring and the metal gasket. so of the other ones (metal one I first bought) did not have o-ring and the gasket was some cheap paper crap. I went with the plastic impeller. Mine last 98k, no to worried about using a new OEM one again.
Old Aug 13, 2015 | 10:05 AM
I'd change both the pump, the crossover, any old hoses, and the tensioners for sure. These are not the kind of cars you want to get stuck out somewhere with a major problem -- especially overheating due to an easy to replace pump, or a destroyed engine due to the 100% inevitable failure of the tensioners. Mileage is unimportant now. 15 years on components is important. If I were you, I would change every hose, including the ones under the plenum if there is no record of it being done. When you pull the cam covers you will need new gaskets, and maybe some plugs and inspect the coils. There is a great tutorial from this site on doing it yourself, but you need patience and double check everything at each step. Those cams must be locked down from above and at the flywheel just in case. Figure on a few days of dinking around and refreshing a lot of old things. Then, hit the road and enjoy. I also upgraded my brakes at the same time.
Old Aug 14, 2015 | 03:55 PM
Ophitoxaemia's Avatar
In addition to changing the hoses you might also inspect all the (many) plastic parts in the coolant system. Many of mine have become brittle and cracked. I had the small piece that goes from the reservoir to the thermo tower crack inside the rubber hose, invisibly clogging it up.
There is a thread somewhere on the site that gives the same water pump part but in a Lincoln box for less than the one that comes the Jaguar box.
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
