Waterpump
Old Jul 11, 2016 | 07:44 AM
mrplow58's Avatar
Default Waterpump
The water pump I installed in my car came with a gasket, but no O ring, and there was no O ring on the water pump I removed. Is the O ring necessary. If it is, I guess I will be doing the job again......Thanks.......Mike
Old Jul 11, 2016 | 08:17 AM
test point's Avatar
Mine came with a stamped steel 'gasket', no 'O' ring. The thermostat has a split rubber seal that goes around the edge.
Old Jul 11, 2016 | 10:12 AM
mrplow58's Avatar
This is what mine came with, but SNG Barratt shows 2 sizes of O rings also. After all the trouble I went through finding this engine, I don't want to screw the pooch, and burn this one up. It has no leaks.......Mike
Old Jul 13, 2016 | 10:41 PM
brgjag's Avatar
this is what came off my 03, will fit your car, this is what I put back on it.
http://www.ebay.com/itm/Engine-Water...ZW9orJ&vxp=mtr
kiddhan625
May 18, 2016 11:36 AM
sgk1935
May 4, 2016 09:18 AM
AL NZ
Apr 27, 2016 08:05 AM
Kief
Apr 26, 2016 10:29 AM
dskul1
XJ40 ( XJ81 )
Apr 19, 2016 09:48 AM
