weatherstripping coming loose
Old Sep 28, 2011 | 03:17 PM
randyb's Avatar
Default weatherstripping coming loose
01 convertible and the weatherstripping on the drivers side that runs along the front half of the window keeps coming loose and I press it back into place and then 2-3 times later, when the top is closing it will drop back down.
Would it be alright to use weatherstripping glue to hold it in place or is there something else I can do to prevent this from happening again?
Old Sep 28, 2011 | 06:22 PM
H20boy's Avatar
it probably is really dry, you should get some Gummi Pflege Stift (rubber care stick) and give the entire weatherstrip a couple good coats of it, get into the cracks and around the grooves where it fits into the hood rail. It may expand enough to stay put AND never need anything else. It also helps keep the window seals tight...squishy is better.
aholbro1
Dec 29, 2024 06:46 PM
Russ Graber
Feb 23, 2019 11:59 AM
GordoCatCar
Jan 2, 2017 01:10 PM
AL NZ
Sep 4, 2015 08:39 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
