Weird electronic fault? 05 XK8
Old Feb 22, 2016 | 01:43 PM
zidjan's Avatar
Default Weird electronic fault? 05 XK8
Hi guys,
I lost my sport mode, J-gate, ABS and DSC over the weekend for about 2 hours and came back....WTH??
So the story is like this: I always defaults on sport mode, I shifts with my J gate from time to time and turn off the DSC when the weather is nice and dry which is what we got here in PDX on Saturday...so anyway, I was about to pull off from a traffic light in a mean spirited way...so I put my J gate at 2nd gear...when I pressed the accelerator, the car acted as if it's in "D" but I am at 2nd??? shifting it up and down does nothing...then I realized my sports mode button is not working (no light) and felt that ABS is not working...so I ended up driving it lightly to do my errands...so after 2 restarts...suddenly everything is as normal....anyone has experienced this?? I just replaced my battery with Duralast Gold 49H8M.
so what happened there?? any clue?? it's been fine ever since....no codes nothing.
Old Feb 23, 2016 | 03:34 AM
jamdmyers's Avatar
You may have to clarify a bit more, Sports mode does not affect manual shifting from 2-3-4-5(on 4.2) on the Jgate so if it wasn't shifting there's a clue. A intermittent hit on ABS maybe the sensor needs cleaned and connections checked.
Old Feb 23, 2016 | 09:21 AM
Jon89's Avatar
Agreed. With intermittent ABS/DSC faults, you always start by cleaning all four wheel speed sensors and checking their harnesses for splits, cracks, or breaks in the wiring sheaths. Reverend Sam posted a video here a few years back that shows you exactly how to do this using a small bowl of water mixed with dishwashing detergent and an old toothbrush....
Old Feb 23, 2016 | 10:49 AM
zidjan's Avatar
Yes I know about the wheel sensors being dirty...however I don't get any message at all...no error code no nothing....and when the sport's mode was out so does my ability to manual shift ... u can put it in 2-3-4-5 but in actual it's in "D" ... that's why I said it's weird...been driving it for 2 days now and everything is fine.... so confused.
Old Feb 24, 2016 | 06:01 AM
jamdmyers's Avatar
There are a couple relays/switches within the shift mechanism, search the forums I've seen them discussed before, verify they are adjusted correctly and any electrical connectors are seated properly, I think you need to remove the center console but check the orig threads. Sorry I cant think where they were listed
Old Feb 24, 2016 | 11:42 AM
zidjan's Avatar
I will look into the relays and switches ..thank you.
MrBW
Feb 11, 2016 08:40 AM
KayScotts
Feb 6, 2016 01:03 AM
phyllisita
Feb 5, 2016 06:11 PM
mikin
Feb 3, 2016 09:52 PM
hproesel
Jan 28, 2016 08:50 PM
