Weird Transmission Fault
Old Dec 13, 2012 | 04:28 PM
JajJohn's Avatar
Default Weird Transmission Fault
It's been getting cold some night here lately. And when starting the car the xk8 I get a transmission fault as soon as the car starts. This is before I put it gear It only happens when the outside temperature is 40F or lower. I let it get to operating Temp and turn the car off and restart it and it is fine. I get an engine light sometimes and the code I pull up is P0763 which is solenoid c. As I said it only happens when the temp is cold and the car has set around 8 hours. One other thing I noticed is it takes longer to crank when cold and I'm thinking it is battery related. Thoughts?
Old Dec 13, 2012 | 05:23 PM
Originally Posted by JajJohn
...... This is before I put it gear It only happens when the outside temperature is 40F or lower. I let it get to operating Temp and turn the car off and restart it and it is fine............. One other thing I noticed is it takes longer to crank when cold and I'm thinking it is battery related. Thoughts?
I'm thinking the same thing.
Old Dec 13, 2012 | 08:26 PM
Gus's Avatar
Gus
If you can get under the car you want to look at the bayonet plug to the transmission (the one connecting to the trans) and see if you have a poor connection in one of the pins. Use a good contact cleaner and a little dielectric grease. Not a common problem with Jag but has been noted with other ZF transmissions.
Old Dec 14, 2012 | 04:48 PM
JajJohn's Avatar
Tomorrow is going to be in the 50's I'll get the new battery and clean and lube the plug. I need to change the fuel filter as well. Thanks for the input.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
picard
Oct 12, 2015 11:56 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
tonyforman
Sep 10, 2015 07:23 PM
