Wet rear floor
Old Sep 19, 2023 | 08:37 PM
erjent's Avatar
Default Wet rear floor
Hi All,
I'm hoping against hope since I haven't pulled anything apart yet, but my carpet behind the driver's seat on my 2000 XK8 convertible is pretty damp with an oily feel. Which hose would most likely be routed in the center of the floor?
Do the hoses tend to break mid run? Can they be repaired, or is it more prudent to just replace ALL hoses?
Much thanks,
Eric "erjent" Jordan
Punta Gorda, Fl
Old Sep 20, 2023 | 01:48 AM
Pistnbroke's Avatar
Pull the back seat up ..if its full of water you have a leaking side window. The water fills the space under the rear seat and overflows into the rear area and then runs forwards to rot out the drivers floor pan...that was my 97 experience
Old Sep 20, 2023 | 04:47 AM
NorXKR's Avatar
The hydraulic hoses for the convertible top is routed along the transmission tunnel on the driver side, from the back seat and to the front of the driver seat. (on LHD cars)
It is rather unlikely that the hoses fails there but who knows? :-)
Old Sep 20, 2023 | 05:28 AM
erjent's Avatar
Thanks for the reply. No, the car has been parked in the garage for almost a year. Hasn't seen any rain.
Old Sep 20, 2023 | 05:29 AM
erjent's Avatar
Thanks for the reply. I guess it's time to tear apart the interior.
Old Sep 20, 2023 | 05:55 AM
cjd777's Avatar
Good chance it's the ram but normally there will be a puddle at the back of the door on the ground.
If you look at the hoses in the trunk on the passenger side, right beside the tank, they run from the pump to the areas needed in the car.
Genberally you can see the flacking of the outside of the hoses all over the floor.
Old Sep 20, 2023 | 04:17 PM
erjent's Avatar
Thank you! I have noticed some flaking, I'll be checking this out.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Jenise
Feb 18, 2022 06:33 AM
Moosey
Nov 10, 2019 06:49 PM
XSkate06
Aug 16, 2018 10:05 AM
Dnjaa
Aug 2, 2016 04:42 PM
