What could it be?
Old Jun 15, 2017 | 11:56 PM
bcprice36's Avatar
Question What could it be?
During the past couple of months, as I'm driving thru George Bush Park at about 50MPH. I've noticed a Wind Noise over on the right-side of the Texas Coupe...I first thought that I had accidently hit the switch and rolled the Right Window down but it was still all the way up! Now I hear it every day.....Does anyone know what could be happening? I've checked all the rubber gaskets around the Door and Window and they all look good as new! Could it have something to do with the A/C System? Which seems to be operating just fine......
I would appreciate some help! It's 2005 XKR Coupe.....and has over a 1,000 miles on the clock!
Billy Clyde in Houston
Old Jun 16, 2017 | 02:20 AM
mhminnich's Avatar
Wow Billy. Over a thousand miles already?
I'd first shut off the climate system to see if the whistle goes away. Vary engine speed (not vehicle speed) to see if it changes in pitch. I wouldn't discount it coming from under the bonnet.
Old Jun 16, 2017 | 02:22 AM
This ONLY happens driving through the Park?
Old Jun 16, 2017 | 07:01 AM
Jon89's Avatar
I have tracked wind noise on several of our vehicles over the decades to a couple of different sources:
1. Wiper blades parked just slightly too high on the windshield. Adjusting the blades down an inch or so cured it.
2. Side mirror cowls whistling at various speeds. Adjusting the cowl position slightly cured it.
Front grills can also start making wind noise if any of their tines get bent or twisted even slightly....
Old Jun 16, 2017 | 03:26 PM
woox4's Avatar
Have you tried resetting your window limits?
Old Jun 16, 2017 | 08:58 PM
bcprice36's Avatar
Yes Graham, I know! Don't drive through the Park!
Billy Clyde
Old Jun 16, 2017 | 09:22 PM
jeremys's Avatar
If this is a vert try putting the top up?
Old Jun 16, 2017 | 10:10 PM
bcprice36's Avatar
Smile Jeremy you must be from Jersey!
Jeremy, My Man! This is the "Texas Coupe"....I put the Top up a long time ago! I really am trying to get some help here.....Any other ideas?
Old Jun 16, 2017 | 10:21 PM
bcprice36's Avatar
Cool Woox4 and window limits.....
Woox4, I've sprayed Rubber Lube on all the rubber gaskets and rolled the Windows up and they are sealing really well.....I don't think they are in need of adjustment.....It's more down in the Floor Area.....
Billy Clyde
Old Jun 16, 2017 | 10:35 PM
bcprice36's Avatar
Default mhminnich
mhminnich, I will try shutting down the A/C tomorrow, as I drive through the Park! What if the noise stops? Can't drive around down here without A/C....Anyway, I will try your ideas and let you know what comes of it!
Thanks a bunch!
BC
Old Jun 16, 2017 | 10:50 PM
Ungn's Avatar
My coupe had a ticking noise in the left B pillar, I just drive faster until it goes away.
I don't think mine is wind, but wind can make a lot a noise if it hits a harmonic with the rubber. I can play the kazoo bagpipes on miata windshield trim at 45 mph.
Old Jun 16, 2017 | 11:18 PM
mhminnich's Avatar
Tough it out Clyde. Lol. 96 today and I've been without AC now for a week. New pressure switch arrives tomorrow for my coupe. Can't be too soon!
Old Jun 17, 2017 | 09:08 AM
dieseldoc's Avatar
You could use a smoke machine inside the cabin and see if there is any external leaks. May need 2 people have one person inside directing the smoke around window seals, door seals, etc and other person on outside looking for traces of smoke. Good luck.
Old Jun 17, 2017 | 09:59 AM
Dr. D's Avatar
Howdy Folks:
Can we rule out the radio antenna being extended? The main reason I have the stealth ANT mod is wind noise while my entertainment center is on, but not listening to broadcast radio.
Old Jun 17, 2017 | 09:39 PM
bcprice36's Avatar
Smile The Hot Jag Coupe!
I would hate to be in Arlington without A/C...as a matter of fact, I would hate to by anywhere without A/C! Surely do hope your part came in Today! and just think, it's only June......
BC
Old Jun 17, 2017 | 09:45 PM
bcprice36's Avatar
Default The Antenna to nowhere!
Originally Posted by Dr. D
Howdy Folks:
Dr. D You know I don't listen to the Radio anymore, only CD's but your right, the Antenna is still sticking-up about 6'or 8'.......I'll try that tomorrow and let you know......
Billy Clyde
Old Jun 17, 2017 | 09:58 PM
bcprice36's Avatar
Thumbs up Dieseldoc, I'll hit the smoke and see.....
I just can't see how it could be the Windows but I've learned to never let a good suggestion go by.....We shall see!
BC
Old Jun 17, 2017 | 10:21 PM
bcprice36's Avatar
Default The Grill?
Jon89, The Wipers might be the problem, I'll let you know! They do stick out there a bit.....but the Grill...I looked it over and I don't see anything bent!
Although the 2005-2006 XKR Mesh Grill is larger and more Convex than the other Models. That would be a reach, I think..... I'll let you know!
BC
