What to do about the antenna?
Old Jul 12, 2018 | 08:51 AM
Beep777's Avatar
Default What to do about the antenna?
This newer to me car already had the stock antenna missing and came with a crappy flexible antenna which already got caught in the trunk and broke off. Having a functional antenna to pick up radio signal is not high on my list. Good looks are higher.
My options:
1. Replace with stock and unplug power so it doesn't extend.
2. Get rid of antenna and have body shop fill in.
3. Other?
Has anybody replaced the stock with a small shark fin? I might try that if they produced an angled one instead of just flat.
Let me know your ideas.
B
Old Jul 12, 2018 | 09:24 AM
JimmyL's Avatar
I replaced mine with one off fleaBay. I've done this with my old XJ8 too. They cost $30 - $40. They last at least a couple of years, and once you do it a couple of times it's not too bad to replace them.
Old Jul 12, 2018 | 12:30 PM
larueb's Avatar
I purchased a used OEM from Coventry West and did the total replacement as my motor was failing. Easy job and has been fine for like 4 years or so.
Old Jul 13, 2018 | 06:58 AM
Fulton's Avatar
Replaced mine with an OEM, left it unplugged and used a hidden antenna I got off ebay. doesn't work quite as well but at least it doesn't look like a mast from the Blue Nose.
Old Jul 13, 2018 | 08:50 AM
Beep777's Avatar
So return it to stock is what I am hearing. Anybody do anything different but still keep it understated?
B
Old Jul 13, 2018 | 03:43 PM
rothwell's Avatar
I would just restore the stock setup and then do the Antenna Switch Mod to limit the antenna's up time to only when the radio is used.
Moseleykmc
May 13, 2020 11:50 AM
coudamau
Jan 3, 2014 12:04 PM
XJ40ish
Audio/Visual Electronics
Jul 7, 2013 08:01 PM
Humy
Apr 22, 2013 04:51 AM
