What is leaking into the trunk??
Old Jan 12, 2010 | 11:52 AM
esterojag's Avatar
Default What is leaking into the trunk??
I noticed on my just purchased 2001 XK8 convertible 51K miles that there is some sticky fluid in the bottom of the trunk under the battery. There are some drops on the garage floor. Could it be leaking from the pump area and if so is this a major repair? Any help is much appreciated.
Old Jan 12, 2010 | 12:00 PM
daddyo007's Avatar
go to Gus's website for more info on pumps.
www.gusglikas.com/autorepair.htm
Old Jan 12, 2010 | 12:14 PM
H20boy's Avatar
whats the color of the fluid?
Old Jan 12, 2010 | 03:48 PM
daddyo007's Avatar
I should change my status to junior member. I always jump and then look!
Hey it could have been that diet cola/pop the prep guy spilled in the trunk prior to you picking up the car. Dry cola is the worst kinda sticky.
Old Jan 12, 2010 | 05:30 PM
Gus's Avatar
Gus
It could be a hyd fluid leak from the pump area that is just above the battery or if it is leaking from just in front of the rear tire it is more than likely a roof lift that is leaking. I say leaking rather than failure is because the cylinder will continue to work as it is leaking.
Old Jan 14, 2010 | 07:11 AM
esterojag's Avatar
The fliud is clear and is very sticky. It is under the panel that the battery sits on so I cannot tell if it is just from something that spilled?
If it is hyd fluid I will have it checked out.
Old Jan 14, 2010 | 10:10 AM
H20boy's Avatar
if that much leaked out to pool under your battery, your hydraulic top reservoir should show very low, check that first. If its between high and low marks, check that off your list. I'm gonna go out on a limb and say that previous owner spilled something in your trunk, and only surface cleaned it... not going deeper under the battery. I mean...would you?
Old Jan 14, 2010 | 01:31 PM
daddyo007's Avatar
Like I said diet cola/pop.
Old Jan 14, 2010 | 02:57 PM
H20boy's Avatar
You'll definitely be the 'spill' guru if that turns out to be the case, contratulations, you should be proud daddyo007up.
get it?
Old Jan 16, 2010 | 06:03 PM
LinksXK8's Avatar
Have you checked to see if your top will operate? & what water boy was saying check level in pump resevoir
Old Jan 19, 2010 | 09:24 AM
esterojag's Avatar
The top is working fine ( hope I do not jinx myself)....
How do I remove the covering in front of the pump to check the fluid level??
Thanks for the continuing help.
BR
Old Jan 19, 2010 | 12:22 PM
H20boy's Avatar
if you're talking about the gray carpeting covering the cd-changer/Nav unit location, it simply pulls down and out (easier if you remove the battery cover as well)
Old Jan 19, 2010 | 04:20 PM
Gus's Avatar
Gus
Use this link to my page it has instructions to get to the pump http://www.gusglikas.com/AutoRepairJ...esRelValve.htm I hope this helps!
Rivguy
Dec 4, 2020 07:55 AM
martybmw
Apr 2, 2016 04:55 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
prettydaim
Sep 7, 2015 05:16 PM
