Wheel alignment - "we cant do it. Every adjustment changes previous setting"
Old Mar 16, 2019 | 11:12 AM
Johnken's Avatar
Default Wheel alignment - "we cant do it. Every adjustment changes previous setting"
Like a few of us lately I am trying to fix inner edge wear.
I replaced front tires, replaced upper shock mount (only 1 side was defective). Ride height is now good, identical both sides.
This morning I brought her to a local tire shop for alignment. I could see they never removed front wheels.
After an hour, they drove the car out and explained that they couldn't do the alignment. They explained that each time they made an adjustment it changed the previous sides setting. There will be no charge.
I asked for the spec readout, it was unavailable "since they did not complete the alignment."
Since they left the wheel on, it tells me they only played with the toe.
Before I write this shop off as inept, I wanted to check in with you guys and make sure I'm not missing something I should look into.
I believe the bearings and bushings are tight. Is there something I might be missing?
Can one set the toe without working with the caster?
Thanks for your advice. I'll find a better shop, just don't want to miss anything.
John
Old Mar 16, 2019 | 11:57 AM
CorStevens's Avatar
contact Euro-Tire, 500 US-46, Fairfield, NJ 07004
www.eurotire.com
excellent workmanship, they should be able to figure it out. probably the best alignment and suspension technicians in the tri-state area.
afonda
Mar 17, 2019 07:43 PM
Alexv12
Nov 10, 2015 11:34 AM
ChrisJay
Nov 10, 2015 10:46 AM
Safari
Jun 3, 2015 06:42 PM
jaguars4r
Nov 11, 2012 07:26 AM
