Where does the fuel pressure go? 2003 Convertible
Old Jul 22, 2014 | 01:18 PM
jjgreer2002's Avatar
Default Where does the fuel pressure go? 2003 Convertible
Hard to start. Cranks well and runs fine when it finally starts. I've replaced the fuel filter, then the pump, then the pressure sensor. When I measure the pressure at the rail it is near zero. When turning key to ON the pressure blips slightly. Sometimes it builds if I cycle the key off and on a few times. When cranking the pressure comes up slowly and finally after starting it is steady at 50psi. When turning off the key it immediately falls to near zero. This is the non return to tank system with a single pump. There's a rubber hose with a round can on it going from the rail to somewhere out of sight on the drivers side. I get the feeling that something is allowing the rail pressure to quickly bleed. No service lights or codes thrown. Can't get my head around it. Any advice?
Old Jul 22, 2014 | 02:58 PM
H20boy's Avatar
check the fuel pressure regulator on the passenger side, just in front of the rail. Mine was cracked and leaking, but it is a small diaphragm inside that releases pressure on the fuel rail when needed. It has a line going to it and away from it.
Old Jul 22, 2014 | 03:53 PM
WhiteXKR's Avatar
There are some 2003 and later replacement pumps with bad check valves. See https://www.jaguarforums.com/forum/x...l-pumps-78107/
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
