Whining noise when using butchered CD changer method and revving
Old Mar 29, 2011 | 11:50 AM
WhiteXKR's Avatar
Originally Posted by jagosaurus
But the noise issue is there with the signal cables disconnected from the cd changer.
I thought you meant unplugged from the RCA connectors. Do you mean completely undoing the wiring?
So you suggest to ground the iphone signal RCA ground to the chassis close to it? Shouldn't its ground be close to or shared with the power amp?
A good chassis ground connection is lower impedance than any wire. Very close to the amp is good, but running a a ground wire from the amp to the iPod is not as good as a chassis connection.
I can make a cable shield for the cable stubs in the cd changer and see if that helps, also ordered an 12 amp alternator noise eliminator I can play with.
Also, the noise is still there if connecting the iphone in the trunk (running on its batteries).
The noise eliminator might help Does it install on the alternator or in series with the electronics? Still think you might need continuous shielding on the cable as well as inside the changer.
Old Mar 29, 2011 | 12:07 PM
jagosaurus's Avatar
Only when it's on
Old Apr 1, 2011 | 02:48 AM
jagosaurus's Avatar
Got a new ground loop isolator from PAC: Amazon.com: PAC SNI1 Noise Isolator: Automotive
And connected its ground to the bolt bolting down the amp/cd changer rack. Problem solved. Next up I want to try to remove it from the signal path and just do the grounding
I've also received a power line ground loop isolator I could try, which i'd like better since it wouldnt be in the signal path.
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
baskervillema
Oct 1, 2015 06:43 PM
