Wider Tires
Old Aug 29, 2012 | 02:13 PM
Dmfinley's Avatar
Default Wider Tires
My 2003 XKR has factory 18 x 8 front wheels with 245-45-18 tires. Rear are 18 x 9 with 255-45-18. Looks like stepping up to 255-45-18 front and 275-40-18 rear would easily fit on existing wheels and be a bit wider.
Has anyone tried these sizes and can anyone think of cons to doing this?
Thanks!
Silver 2003 XKR Coupe
Edmond, OK
Old Aug 29, 2012 | 02:39 PM
Brutal's Avatar
I run 255/40 and 275/40/18 on xkr wheels front and rear and they tuck just fine on my 96 sedan.
Cons=more expensive, less mpg due to increased rolling resistance and weight
pros=handle better, better traction, brake better, look better, make you look thinner
anything else
BTW I RUN NITTO INVO'S
Old Aug 29, 2012 | 06:43 PM
ccfulton's Avatar
Originally Posted by Brutal
I run 265/40 and 275/40/18 on xkr wheels front and rear and they tuck just fine on my 96 sedan.
Do you run 9" wheels all around, or the stock 8/9 setup? 265 is a lot of tire for an 8" wheel.
Old Aug 29, 2012 | 09:03 PM
pomosv's Avatar
On my stock 18's I ran 245's up front, and 275's on the rear. AND that was with a +1 inch spacer, no issues
Old Aug 29, 2012 | 10:17 PM
Brutal's Avatar
oops, fat fingered that one. I run a 255 in front and yes 8" front and 9" rear. also think a 255/45 would be too tall. On a XK the rear well is LARGE. And a taller tire to fill would look better. Say a 265/45. The best thing you can do is to look at the tire manufacturer spec thier tires at and compare because all size tires are NOT the same sizes as some of you may/may not already know
Old Aug 30, 2012 | 08:43 AM
SteveM's Avatar
I would think a wider tire would handle worse with more sidewall flex and bulge. A wider tire on a wider wheel is a different matter.
MrWhite
19
Jun 14, 2022 07:49 PM
RedRider48
Oct 1, 2015 08:18 AM
XJ8JR
Sep 29, 2015 06:59 PM
42Ajd
Sep 26, 2015 07:04 PM
