Window control module programing
Old Jan 21, 2025 | 07:40 PM
Mgorman's Avatar
Default Window control module programing
97 XK8 coupe. Passenger window lost its mind. Went completely erratic. I pulled out the module, opened it and found a nice little burnt spot. Getting a replacement with the same part number is easy. Mine has a sticker on it that says Download 25P which I suspect refers to its particular program. None of the ones I see for sle have such a sticker. Question is if I get one from an X100 coupe will it need to be reprogrammed? If so, who still has that capability? Thanks for any help.
Old Jan 22, 2025 | 01:32 AM
Pistnbroke's Avatar
Usually just put it in .....take window to top hold till it bleeps then go fully down and hold again job done. Thats for an XK8
Old Jan 22, 2025 | 08:11 AM
RichardS's Avatar
Originally Posted by Pistnbroke
Usually just put it in .....take window to top hold till it bleeps then go fully down and hold again job done. Thats for an XK8 unit dont know about X100 let us know
Isn't the XK8 covered by the X100?
Richard
Old Jan 22, 2025 | 12:16 PM
Mgorman's Avatar
Richard
Yes, that’s my understanding.
Old Jan 22, 2025 | 01:22 PM
Pistnbroke's Avatar
Brain failure ..it will come to you
Old Jan 22, 2025 | 03:49 PM
Silverjag0's Avatar
Remove the battery before you install it
​​​​​​If car refused to lock then connect both battery together for about 10 seconds that will reset everything good to go
Old Jan 22, 2025 | 04:12 PM
Pistnbroke's Avatar
Both battery cables !!!!! discharges all the capacitors in the system
Old Jan 22, 2025 | 04:49 PM
Silverjag0's Avatar
Old school here and not electric geek that's what work as it is pass it my friend
Old Jan 23, 2025 | 01:20 AM
Pistnbroke's Avatar
I was clarifying your english as some might take it to mean join the battery terminals as you missed a word out of your sentence
"​​​​​​If car refused to lock then connect both battery CABLES together for about 10 seconds that will reset everything good to go "
Old Jan 23, 2025 | 08:19 AM
Silverjag0's Avatar
That's what i meant my friend , English not my first language so sometimes I forget to write properly . Thanks to clarifying
virtue4u
Jan 13, 2025 07:02 AM
evanscornelius
General Tech Help
Jun 10, 2024 04:52 PM
Muppet
Apr 10, 2021 10:12 PM
Spolo85
Oct 5, 2018 06:35 PM
dlpfrench
Oct 9, 2016 10:11 AM
