Window control module programing
97 XK8 coupe. Passenger window lost its mind. Went completely erratic. I pulled out the module, opened it and found a nice little burnt spot. Getting a replacement with the same part number is easy. Mine has a sticker on it that says Download 25P which I suspect refers to its particular program. None of the ones I see for sle have such a sticker. Question is if I get one from an X100 coupe will it need to be reprogrammed? If so, who still has that capability? Thanks for any help.
Richard
I was clarifying your english as some might take it to mean join the battery terminals as you missed a word out of your sentence
"If car refused to lock then connect both battery CABLES together for about 10 seconds that will reset everything good to go "
That's what i meant my friend , English not my first language so sometimes I forget to write properly . Thanks to clarifying
