window creep
Old Jun 1, 2018 | 04:12 PM
pjc2063's Avatar
Default window creep
Hello everyone,
The drivers window on my 2006 XK8 convertible creeps down an inch or two while parked or sitting in garage. Otherwise works fine, goes up and down. But when I return to the car I see the window has lowered about 1-2 inches. Same in my garage. Any one else have this problem?
Old Jun 1, 2018 | 04:50 PM
fmertz's Avatar
Probably early signs that the battery will need replacement sooner rather than later. Do the window reset procedure. Lower both windows down and hold the button in the down position for a couple extra seconds until you hear a faint click. Then roll the windows up and hold the button in the up position until you hear a faint click again. Do this separately for each window.
Best of luck, keep us posted.
Old Jun 1, 2018 | 08:45 PM
StuG's Avatar
+1
DWS (Dropping Window Syndrome) can usually be cured with a new battery.
Old Jun 2, 2018 | 12:56 PM
pjc2063's Avatar
Thanks for your help. I will have the battery replaced. Probably needs it, 5 years old.
Old Jun 4, 2018 | 03:25 PM
Ophitoxaemia's Avatar
I had this, but the cause was a parasitic drain. So if the new battery doesn't fix it, check that.
Leichardti
Sep 6, 2014 04:35 PM
Jag Pilot
Jul 4, 2013 10:09 AM
Silver99XJR
Oct 5, 2012 05:22 PM
sbreeden
Aug 5, 2012 08:31 AM
mechelement
Jun 15, 2012 01:44 PM
