Window / Door waist adjuster lock nuts
Old Dec 21, 2018 | 04:45 PM
volkris's Avatar
Default Window / Door waist adjuster lock nuts
Hi, all
The Door Window Glass Adjustment procedure mentions something called "door waist adjuster lock nuts" that are to be slackened before the adjusters are hand screwed until they abut the door glass stops. The nuts and adjusters are missing in my car.
Anyone know off the top of their head what these things are and what function they serve?
Here's the step of the procedure. The adjusters are supposed to be near the top of the door, and I have just empty threaded holes.
Old Dec 21, 2018 | 10:27 PM
Johnken's Avatar
V, Mot sure but from their position it looks like they are the upper fasteners for the vertical window channel. I'm sure it'll be obvious when you get in there.
John
Old Dec 22, 2018 | 02:39 AM
Muncie6spd's Avatar
The illustration is for a 2003 XK, are you sure it would be on your 1997?
Old Dec 22, 2018 | 02:42 AM
volkris's Avatar
Nope, not positive, but like I said I do have two threaded holes in the indicated places, so I suspect it is the same.
Either way, searching the history of this board I haven't seen an answer to this question. Even if it doesn't apply to my car, maybe someday someone else would appreciate the answer.
adrianbond
Feb 22, 2022 05:29 AM
doug owens
Oct 29, 2018 03:03 PM
doug owens
Oct 22, 2018 02:19 PM
kreyszig
Aug 10, 2016 06:53 AM
Sparky77
Jun 22, 2016 03:26 PM
