x type rear door window waist seal
Old Oct 15, 2018 | 03:41 PM
doug owens's Avatar
Default x type rear door window waist seal
jaguar x type saloon 2004 uk
Old Oct 15, 2018 | 03:44 PM
doug owens's Avatar
T hank you for reccomendation of rimmers. £i was hoping to find much cheaper part £80 for 2 bits of trim any other ideas please
Old Oct 15, 2018 | 10:13 PM
iownme's Avatar
im not sure where you can find a rimmer these days
Old Oct 16, 2018 | 03:25 PM
Dell Gailey's Avatar
U.k. based parts supplier
Old Oct 18, 2018 | 11:04 PM
Dr dome's Avatar
Do you need the rubber trim around the door? If so i can ship you one. Im sure it will still be cheaper then new. Let me know.
Old Oct 19, 2018 | 05:36 AM
doug owens's Avatar
Hi Thank you My rubber seal is good
Old Oct 19, 2018 | 03:02 PM
Doug, Dr. Dome is a member here who parts out X's. He probably has some waist seals as well.
Dr., they're the ones that "wipe" moisture off glass as you lower or raise the window. Usually the ones everyone complains about bubbling from rust corrosion of underlying metal substrate. Seen some other model owners that have stripped and sanded, primed and painted the metal ones on theirs. Apparently it is a manufacturer defect of them not using an etching primer on those other models prior to base coating them.
Old Oct 20, 2018 | 06:18 AM
doug owens's Avatar
Hi Dell Many thanks for your reply. What a shame Jaguar hadnt thought through the metal clipp If only had been zinc coated. I think I may have to go the Route you suggest anind bight my tounge on the cost. Thanks aga
Old Oct 29, 2018 | 01:10 PM
doug owens's Avatar
Wink Door waist sillls
DO YOU HAVE CONTACT E/M ADD OR PHONE NOS FOR DR DOME many THANKS
Old Oct 29, 2018 | 02:24 PM
For obvious reasons we don't post email addresses or telephone numbers on the forum.
Send Dr dome a PM (Private Message) or a forum email by clicking on his forum name at the top left of any of his posts.
Old Oct 29, 2018 | 03:03 PM
https://www.jaguarforums.com/forum/m...r-dome-135469/
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
