Window Issue
Old Apr 10, 2012 | 02:42 PM
newmansjag's Avatar
Default Window Issue
Few weeks back, while raising drivers side window it began falling forward at the half-way to the full closed position. If door is closed window stopped as it rubs into rubber molding. I figured out that if I hold the window with my free hand, pulling up & back at the half up position while raising, it closes fine.
I just reviewed Sam's video on window adjustments but don't believe these adjustments would remedy problem. Window is still air tight, rubber gaskets in good shape. Only thing I've noticed since owning Jag is a slight noise at that half way up area.
Anyone have similar experience?
Old Apr 10, 2012 | 06:30 PM
WhiteXKR's Avatar
Remove the door panel and look for a loose or missing bolt between the window mechanism to the door. Also look for evidence (paint scraping) of any bolt in an elongated hole that may have slid out of position.
Here is the full set of window adjustments:
File Type: pdf
Old Apr 11, 2012 | 05:07 AM
JoukoN's Avatar
This may be of help:
https://www.jaguarforums.com/forum/x...ustment-70568/
Yes, check the two bolts for sliding. Marked with green stars in the picture.
Jouko
Old Apr 11, 2012 | 06:37 AM
newmansjag's Avatar
Thanks to both. I remember reading both posts in the past, but my recent search was not deep enough.
Old Apr 13, 2012 | 02:32 PM
newmansjag's Avatar
Just finished window adjustment. Fix was the glass lift regulator channel adjuster. Took around 3 hours due to trial and error. No loose bolts or slide wear marks. Soon as I loosen & adjusted nut & tightened, window worked like new. Didn't break anything & door functions work fine. Happy Happy!
Thanks again To Rev. Sam, WhiteXKR and JoukoN.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
GordoCatCar
Jan 2, 2017 01:10 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
