Window issue: drops when opens the door but won't go up!
Old 11-05-2010, 04:20 PM
Hill2302's Avatar
Default Window issue: drops when opens the door but won't go up!
I noticed this today. My passenger open his door and it dropped like it's supposed to. But when he closed it, it didn't roll back up. I pulled the door lever and it dropped some more. Everytime I pulled the handle it dropped a little more. I got back in and turned the key and I could roll the window up with my driver's side control, but when I went over to close the door again, the same thing happened.
I'm hoping it'll be all better when i go to drive home today, but the realist in me thinks I won't be so lucky.
Anyone had this happedn to them before. Any idea on the culprit?
Thanks.
Old 11-05-2010, 04:28 PM
Gus's Avatar
Gus
Gus is offline
Received 2,208 Likes on 1,700 Posts
You need to reprogram the window. To do this you push the window down button and hold until you hear or feel a click. Then push the window button for the window to close and hear or feel the click. This should be done when you are in the car and the door is closed. The window should operate properly by opening a slight bit when the door is opened and close when the door is closed.
This problem is often caused by a weak battery voltage. 10.5 or below they loose memory settings.
I hope this helps!
Old 11-05-2010, 04:31 PM
Hill2302's Avatar
I'll give it a try and see if it works. Thanks for the tip. I'll let you know how it goes.
Old 11-05-2010, 09:22 PM
Hill2302's Avatar
Gus, thanks alot. That did the trick! Such a simple solution. I really appreciate the help.
JarodL
03-07-2024 01:39 AM
99xk8guy
06-05-2023 06:28 AM
99xk8guy
09-21-2019 07:34 PM
dsnyder586
04-04-2019 02:38 PM
GordoCatCar
01-02-2017 01:10 PM
Quick Reply: Window issue: drops when opens the door but won't go up!
