Windows on convertible not closing properly
Old Nov 9, 2010 | 10:00 AM
XK8Rupes's Avatar
Default Windows on convertible not closing properly
Hi
Normally the windows should seal into the hood when you shut your door, well sometimes they do and othertimes they don't?
Also they go up before i close the door so the glass is too high to go under the hood. I find if i send them all the way down and back up they work sometimes.
Whats the problem??
Old Nov 9, 2010 | 11:01 AM
Jag13cat's Avatar
Default Window Adjustment
XK8Rupes - The window movement up and down can be self adjusted by holding the up and down switches for approx. 3-5 seconds at the up and down positions.
If you have already performed this task, go to FAQ in the thread section, scroll down to Interior/Mechanical Issues, go to Adjustment of Window using regulator stop - WITH VIDEO - in which Rev Sam has produced an excellent video on how to remove the door panel and adjust the window regulator mechanism.
Old Nov 9, 2010 | 11:04 AM
Brutal's Avatar
What he is referring to is normally caused by a failed microswitch in the door latch assembly.
Old Nov 9, 2010 | 01:10 PM
H20boy's Avatar
plenty of those posts around here too, start with the FAQ page and go from there. G'luck, its tricky.
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Aus V8S
Nov 13, 2015 11:01 AM
