windshield wiper has a mind of its own
Old Dec 27, 2012 | 04:50 PM
anthonyisd3ad's Avatar
Default windshield wiper has a mind of its own
It was raining here last night and when I turned on the windshield wipers on to the first setting set to a 15 second pause in between they would just continue wiping without stopping and then stop in the middle of the windshield and than start again 15 seconds later. When I put the stalk up to medium speed constant or full speed constant it would continuing wiping than shut off completely until I move the windshield wiper stalk again. It is kind of hard to explain and I could probably post a video maybe tomorrow for those who dont understand.
My question is the motor seems to be working fine. Do you think it can be the windshield wiper stalk?
Old Dec 27, 2012 | 08:15 PM
WhiteXKR's Avatar
Sometimes wiper problems with stopping and starting in the wrong place are indicative of the wiper park switch inside the motor failing. This would mean a motor replacement.
Before going that route though, check the that the two wiper relays (on US cars, drivers side, brake booster compartment, 2 relays closest to windshield) have not unseated from their sockets. Also try swapping those two relays with one another and see if the symptoms change.
As you say, there could also be an intermittant problem in the stalk. To test that you have to open up the steering column cover and cleck continuity in the various switch positions. If you have JTIS, they are in figure 14.1 of the electrical diagram. You can also download the '98 electrical diagram from www.jagrepair.com
Old Dec 27, 2012 | 09:59 PM
But it doesn't just stop. If I set it with a pause in between each wipe it'll do it once or twice and then start going constantly without stopping till it stops either in the down position or half way in the windshield
Old Dec 27, 2012 | 10:28 PM
WhiteXKR's Avatar
Well start with the suggestions I gave with the relays...that is really easy.
If that turn up nothing, then check continuity on the stalk switch using the circuit diagram.
Only if all that checks out would I look at the motor.
The other possiblity is the Body Processor Module, but I think that is least likely to be the problem, especially if the wipers are the only system malfunctioning.
Old Dec 28, 2012 | 06:35 PM
Thanks White XKR as soon as I get a chance to take a look I'll post it up
Old May 3, 2013 | 09:20 AM
m_vrik's Avatar
I have the same problem with my 97 xk8. Took it to a mechanic that claimed some knowledge of the car and he suggested a new bcm. But, no other issues other than the wipers. Did you find out what the problem was with your car?
robbing
Mar 5, 2024 10:51 AM
aode06
Jul 28, 2023 02:26 PM
redxk8
Oct 4, 2015 08:28 AM
davidboger
Oct 1, 2015 10:13 AM
