winter storage question
Old Dec 22, 2011 | 08:04 AM
doc18015's Avatar
Default winter storage question
Can a battery tender be put on battery while connected to car or must the battery cables be disconnected?
What other issues should be addressed ?
Old Dec 22, 2011 | 08:21 AM
Mikey's Avatar
No need to disconnect the battery. I simply fill the gas tanks and let the toys sit till spring.
Old Dec 22, 2011 | 09:12 AM
doc18015's Avatar
Thanks! Will do. Asked because did not want to damage any electrics.
Old Dec 22, 2011 | 06:48 PM
Andy94SC's Avatar
My battery tender is on with the battery still connected in the vehicle.
Fill the tank as mentioned. I wouldn't use any fuel stabilizer, I've had cars sit for years without it and the gas is fine. I've also heard the increased amount of Ethanol in modern fuel does not work well with the fuel stabilizers.
The only other things I might suggest would be to air up the tires a few extra pounds to help combat them flat spotting.
Maybe set up some mouse traps under the car if you ain an area where mice might get in.
Pontsu
Dec 15, 2015 05:38 PM
James007
Oct 3, 2015 03:29 PM
SCMike
Sep 22, 2015 07:34 PM
Arne
Sep 15, 2015 02:47 PM
James007
Sep 6, 2015 06:47 PM
