Wiper problem - Jaguar XK8
Old Mar 14, 2013 | 04:02 PM
Roger Leake's Avatar
Angry Wiper problem - Jaguar XK8
Wiper problem - 2005 XK8 Convertible: Local independent specialist replaced some relays to resolve a throttle problem. When car was returned the wipers only operate on fast speed. Do not self park and no slow or intermittent wipe available. I have sprayed the contacts on the two relays with WD40 and switched the units around but not resolved. Has anyone had similar problem?
Old Mar 18, 2013 | 03:51 PM
xjrguy's Avatar
There are two relays for the wipers......check them both and make sure both of them have five terminals and not just four. Sounds like they may have installed one on/off relay instead of a change-over relay. Easy enough to check.
Good luck!
Old Mar 20, 2013 | 04:51 PM
Steve,
Thanks for your help on this. The relays were 4 pin, have now replaced with 5 pin and all seems to be OK. I guess the garage was playing with a whole range of relays to sort out the previous throttle problem.
chipnping
Mar 8, 2016 10:33 PM
msdg137
Sep 16, 2015 06:24 AM
daro31
Sep 1, 2015 10:24 AM
Jandreu
Aug 29, 2015 07:31 PM
divingmom
Aug 25, 2015 07:54 PM
