xjr has limited slip?? and we dont??
Old Apr 24, 2010 | 01:45 PM
2000blackxkr's Avatar
Question xjr has limited slip?? and we dont??
Ok, i noticed on a add for a 2000 xjr that she has LS.
But our Xkr's do not? ok... is the pumpkin on the XJR the same? am i correct that they have steeper gears as they are a heavier car?
Old Apr 24, 2010 | 01:54 PM
Thomasso's Avatar
I don't think any car with Traction Control has Limeted slip as they wont work together. Traction control brakes the spinning wheel. Limited slip transfers power to the spinning wheel. They can't work together.
Old Apr 24, 2010 | 02:37 PM
Default LS
Cars all over the place have traction control and a LS unit.
Look at almost any 2000 and up Mustang GT.
Old Apr 24, 2010 | 06:41 PM
RJag's Avatar
If you take the traction control off and stand on mine, you get two solid strips of rubber. They are equal in length and that would appear to indicate some form of limited slip?
Old Apr 24, 2010 | 07:35 PM
Gus's Avatar
Gus
Was it fun?
Old Apr 24, 2010 | 08:33 PM
Default ls
They have a really tight open diff, If you prop up the back end, and spin the tire you will see that it is not LS.
Old Apr 25, 2010 | 08:06 AM
Jaxkr's Avatar
If you are looking for a limited slip setup for your car I have all the parts to give you LSD with 3.58 ratio instead of your 3.07. You will have LSD & quite an improovement in acceleration. You will be amazed at the difference.
Old Apr 25, 2010 | 08:53 AM
RJag's Avatar
Yes Gus, it was but I could see little dollar signs in the rubber on the pavement
Old Apr 25, 2010 | 10:46 AM
workoutman0011's Avatar
Hey JAXKR What about the TCM and if you have this down too im defenitly interested could you email me the details?
Old Apr 26, 2010 | 03:34 PM
iilium's Avatar
Hey JAXKR, is there a separate thread regarding your LSD setup? I'm all ears...
xjrjag
Oct 24, 2024 03:09 PM
hunter34
19
Sep 14, 2022 11:09 PM
Matei Dima
Oct 8, 2015 11:45 AM
Ipc838
Sep 13, 2015 03:27 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
