XK8 1996 ABS front hub nut - right or left hand thread? - RESOLVED
Old Aug 17, 2021 | 03:46 AM
xk8v8's Avatar
Default XK8 1996 ABS front hub nut - right or left hand thread? - RESOLVED
Thanks for readng this!
I've got a 1996 xk8 and am just about to tackle the dreaded front wheel bearing. (left hand side)
I've bought the special tool and soaked everything in oil.
Are both sides right hand thread or is the left side left hand thread?
Please, replies only if you've actually tackled this yourself.
Thanks!
Last edited by GGG; Aug 17, 2021 at 07:06 AM. Reason: Add "RESOLVED" to thread title
Old Aug 17, 2021 | 05:31 AM
bladerunner919's Avatar
I've done the left wheel bearing and don't recall anything being left hand thread. I assume you are referring to the ABS ring, which is definitely a standard thread.
Old Aug 17, 2021 | 06:14 AM
xk8v8's Avatar
Thanks for your reply, yes I am referring to the Abs ring.
I took the plunge earlier and yes, as you say, I can confirm to anyone else in the same position that it is a normal thread (despite reading otherwise somewhere else), I just worried at first why I was having to put so much force into it with a large scaffold bar but no movement but finally it went!
For anyone doing the same job, I found the cheapest place to buy the special tool to remove the abs ring was from The Tool Academy (Hardwick Motor Company, Sutton in Ashfield) who have an ebay store, cost £52 and worth buying, just made sure I sprayed plenty of oil around the job several days before I tackled it, to help free off rusty areas.
Old Aug 17, 2021 | 07:09 AM
As you've answered your own question, I've added 'RESOLVED' to the thread title.
Ltd
Oct 13, 2018 06:48 PM
Johnken
Nov 11, 2017 12:42 AM
RaceDiagnostics
Mar 16, 2013 03:26 PM
Two jags
Jan 6, 2010 05:02 PM
