XK8 1997 convertible Window problems
Im having a couple of issues with my front windows on my XK8 hope someone has a idea
1. When i touch the door handle the window drops slightly as i believe it should but when you close the door it doesn't automatically go back up.
2. When i drop the hood passenger window drops slightly drivers doesnt.
Ideals please i have tried resetting them.
Sounds like your reset didn't take. Try it again, more than once if needed. Also try a hard reset of the battery. Then reset the windows.
If that doesn't work, do you have any other odd symptoms? Your battery may be getting weak. Have that checked.
Even though the battery is new, the battery is the cause of this problem 19 out of 20 times. Perhaps the battery was not fully charged when it was delivered or there is something in the car draining the battery. Have it checked out.
