xk8 1998 tensioner replacement
Old Oct 11, 2012 | 12:53 PM
EZDriver's Avatar
The torque values for the cam caps and tensioners are stated in my thread I gave you earlier. If you didn't read it then here it is again. I do not understand your reluctance to replacing the tensiners. Lifting the cam is no problem. I didn't even bother to get the flats level and still had no problem. I just loosened each bolt a little at a time. Would have been better to turn engine to get them flat however. What is your concern?
https://www.jaguarforums.com/forum/x...ics-how-52653/
Old Oct 11, 2012 | 03:38 PM
steveeasy's Avatar
Hi all,
sometimes things can get a little confusing, In my opinion, and it is my opinion, the zip tie method should only be used if the timing is perfect. To check this the cam flats have to be in alignment. (this will reveal if the chains have stretched or not).
Camshafts can break under load. by rotating the camshafts to the spot were every valve is closed, then zip tie the sprocket,, when the cam lobs are unbolted the cam wont role, twist, or end up being jammed.(there is no good reason to try to remove a camshaft under the pressure of valves forcing the camshaft up,).
when new tensioners are installed they need priming before the car is started. if this is not done the chain can jump causing significant damage. prior to starting work on the car, remove the fuel relay(this is in the boot)
when you have changed both tensioners, prior to putting the fuel relay back in, turn the engine over several times until the tensioners fill with oil. only then reinstall the fuel relay.
finally if you put a socket on the crank to rotate the engine, dont forget to remove it.
If you have new tensioners, dont hesitate on fitting them. whist you might think the old tensioners will be ok, they wont. so many owners end up with a broken engine that can cost thousands to repair. Im new to the forum and ive seen no end of threads referring to tensioners breaking causing untold damage.
Best wishes
Stephen
Old Oct 12, 2012 | 04:19 AM
louismacrides's Avatar
Hello I've got both sides apart .so def gonna fit new one .please give me torque settings as I am blind I think its 125 nm and I don't no what it is for tensioner .kind regards Louis
Old Oct 12, 2012 | 04:28 AM
Ps how do u prime them and ware exactly is relay thanks
Old Oct 12, 2012 | 05:02 AM
Just took out left one that's left sat in car
Old Oct 12, 2012 | 06:06 AM
RJ237's Avatar
Torque- There are two numbers given. I have been told the first is for old bolts, second for new.
Tensioner 10- 14 Nm
Cam Caps 9- 11 Nm
Cam Cover 9- 11 Nm Start at center, work toward ends
Ignition Coil 4- 6 Nm
Prime by turning engine over with fuel pump relay removed until oil pressure light goes out.
RJ_________________
97XK8 86Kmi
Old Oct 12, 2012 | 06:20 AM
Thankyou my torque is in pounds can u convert please ,this is my update so far .I've got both new ones in left side is tightened up but not torqued,seem to go well flats were good.the other side different story.the flats were out about hafl a cm .and the end of cam nearest sprocket won't sit down flush but the rest does .I also notice I had to take pin out of tensioner to get it in any advice please
Old Oct 12, 2012 | 06:23 AM
  #28
Here you go
Convert for Windows - joshmadison.com
Old Oct 12, 2012 | 06:26 AM
One more thing on tensioner does left bank mean left side and r b right side .as if your sat in car facing forward thanks
Old Oct 12, 2012 | 06:35 AM
  #30
RJ237's Avatar
Yes.
Old Oct 12, 2012 | 06:39 AM
  #31
RJ237's Avatar
Did not catch about flats off half cm. You have a timing problem. Check procedures that use locking tools. Do not put it together as is.
RJ__________
97 XK8 86K mi
Old Oct 12, 2012 | 07:46 AM
  #32
More update flats were good my mistake .both are in and bolted up now just need nm pounds conversion for torque wrench .time for cup of tea
Old Oct 12, 2012 | 08:05 AM
  #33
Sussed it 10.3 pounds foot for tensioner and 8.1 pounds foot for cam caps .hope this is write
Old Oct 12, 2012 | 08:17 AM
  #34
You are right if you are using new bolts, if not the numbers are 7.3 & 6.6 pounds foot.
Old Oct 12, 2012 | 01:09 PM
  #35
Hello latest update .all done very please with my self ,overal took all day but took my time ,is say bout 3 to four hours plenty time to do it.I wasn't please with both my torque renches being to big.I recomend get a small one .in the end I didn't torque tensioner or cam caps with the rench as I felt it was over tightening it so I guessed it but all was nice n tight but not to tight,I cleaned as I went.New tensioners went in easy once I lifted cams but I must admit I was bit nervous and slightly shaky messing with engine,l then went for an hours drive as a treat.very glad I did it.old tensioner still had life in them but did have tiny damage ware u can't see it.they look very brittle,definately doable at home and quite enjoyed it.the flats were spot on both sides ,touch wood all ok now .a big thankyou for everyone's help it really did help me a lot .thanks all
Old Oct 12, 2012 | 02:27 PM
  #36
steveeasy's Avatar
Hi
Glad it went all ok.
stephen
Old Oct 13, 2012 | 03:00 AM
  #37
hello all,id like to add that the ticking clatter noise on right side seems to have gone away,after many years as well.
Old Oct 19, 2012 | 01:50 PM
  #38
Scott M's Avatar
Hi folks, I have a 2001 with 56K on it, Would this year have the faulty tensioners?
Old Oct 19, 2012 | 04:34 PM
  #39
Jag#4's Avatar
Unless they have been changed, 2001 MY has the faulty version.
Old Oct 20, 2012 | 04:31 AM
  #40
Get ya tools out.you will learn loads,sleep better,you might get lucky when u take one cover off you can tell easily .
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
arnoldmilk
Sep 3, 2015 07:42 PM
KarimPA
Sep 3, 2015 07:32 PM
